Did I catalogue incorrectly?
User avatar
s2art
Post by s2art »
Recently I attached a 4TB drive to my NAS and had Neofinder catalogue it. It took nearly 7 days to do this.
The final file is a huge 165+GB.
Did I do something wrong, should I have created a catalogue for each top level folder?
(For what it's worth I create a folder a year and subsequent subfolders for media or hardware type.)
The drive's details are
Size 4.0TB
Free Space 717.7 GB
Files 1,532,176
Folders 400,676
Data size 3.3TB
Catalogue size 165.4GB
Screenshot 2026-08-14 at 16.41.50.jpg (54.7 KiB) Viewed 1465 times
Photographer, Walker, CBD Dweller.
flickr
website
Re: Did I catalogue incorrectly?
yes, for such huge volumes we very much recommend to catalog the top level folders separately, as outlined in the NeoFinder Users Guide:
https://www.cdfinder.de/guide/11/11.1/f ... oging.html
Also, if that disk contain a Time Machine backup, you MUST use very specific settings:
https://www.cdfinder.de/guide/3/3.12/ti ... disks.html
LAst, what size did you ask NeoFinder for photo and video thumbnails? These play a very large part in the catalog file size...
User avatar
s2art
Post by s2art »
Thanks for the response. I redid the catalogue and all is good now.
flickr
website
Wonderful, that is good to hear!
