We are very happy to give you a nice update for the NeoFinder 8.x family, named NeoFinder 8.1.1!
NeoFinder 8.1.1 can catalog Olympus OM-1 RAW – has IPTC image description fields – and many bugfixes
Some of the new and amazing features include:
Catalog thumbnails and metadata of the new Olympus OM-1 camera RAW files (.ORF)
Catalog and Edit the new IPTC standard fields for Accessibility image descriptions ("alt text") and extended descriptions
Find Editor "Path" parameter can use regex for more complex searches
Catalog "Capture Date" including seconds from video files, and some more exotic RAW files
EXIF Capture Date also works for dates prior to 1900, for photo archives and museums
"Metadata" context menu only contains the active commands
Improved cataloging of BlackMagic RAW videos files, uses less memory in NeoFinder
Find Editor "EXIF" has a new parameter to find empty EXIF Capture Date values
Fixes a bug where the "Back" and "Forward" buttons in the main window didn't always work
Fixes a bug where the number of items in Albums and Album Groups wasn't always updated immediately
Fixes a bug in the text-with-tab export, where empty contact fields didn't write the required tabs
Works around bugs in macOS, where the volume creation date of FAT16, FAT32, and ExFAT volumes was completely wrong
Fixes a bug in the More Finder Info Inspector, where the XMP contact data fields were always empty
Fixes a bug where adding a Place from XMP data of a file didn't work if the option "Always add new places to this list" was deactivated
Fixes a bug where the Multi Renamer always added a period character to renamed folders (that feature was actually intended for files only, but hey...)
Fixes a bug where the Find Engine failed to find hierarchical keywords if the "one keyword contains" option was used instead of "one keyword is"
Fixes many minor issues
NeoFinder requires Mac OS X 10.11 or newer, Intel or ARM. Older versions of NeoFinder for previous system versions are still available on our web site
NeoFinder 8.1.1 is available today.
NeoFinder 8.x is a paid upgrade for NeoFinder 6.x, NeoFinder 7.x, and CDFinder customers
NeoFinder 8.1.1 available today!
