EXIF panel addition to Inspector
hmarkweidman
Post by hmarkweidman »
How do I add the Camera Data/EXIF panel to the Inspector panel? When I click on the Gear icon the window that opens is specific to editing Metadata.
Re: EXIF panel addition to Inspector
You can fix that today by using Apples Terminal.app in the Utilities folder, and pasting this exact command line here:
Code: Select all
defaults write de.wfs-apps.neofinder InspectorSectionID-IID-EXIF YES
That will show the EXIF section in the Inspector again.
The upcoming NeoFinder 9.2.1 will have a "Inspector Settings" command in the Window menu of the main menu bar, so it is always reachable.
