View Option Presets
stephengraham999
View Option Presets
Post by stephengraham999 »
Is there any way to create a “preset” of view options e.g different size of thumbnails with different selections of annotations.
Thanks. Stephen
Re: View Option Presets
Not at this time. How often would you want to switch these presets, and how many of those would you need?
We may start with exposing these settings to AppleScript first, so you could customize them and use them by running a small script from the Scripts menu...
stephengraham999
Sorry I thought I’d replied. AppleScript will be good.
OK, great, we will look into that.
