BRU Catalogs to Canister
Q: Does NeoFinder support BRU catalog import/export and if so, is it possible to export said Catalogs for Canister like we do with Pre Roll Post?
A: NeoFinder can indeed Import "ArGest Backup" and "TOLIS Group BRU Tape Archiver" text protocol files and make valuable NeoFinder Catalogs from them:
Then, you can indeed Export any existing NeoFinder Catalog into the Hedge Canister format to use it with that powerful LTO software:
https://www.cdfinder.de/guide/10/10.2/h ... xport.html
