NeoFinder 8.7 available today!
All thumbnails in item - View menu
The View main menu now has the missing All thumbnails in this item command that was already available in the context menu for a while.
This will show you all items with a thumbnail, in the selected Catalog, or folder, and all subfolders inside it.
It will now even work for multiple selected catalogs, and also entire Catalog Folders!
Check it out!
View menu - all thumbnails.jpg (209.58 KiB) Viewed 71338 times
Video chapter markers!
Another exciting new feature in NeoFinder is the ability to catalog video chapter markers, including their name!
And yes, the powerful Find functions in NeoFinder will search these chapter names, too, of course.
https://www.cdfinder.de/guide/22/neofin ... terMarkers
[attachment=0]Video Chapter Markers.jpg[/attachment
Video Chapter Markers.jpg (152.3 KiB) Viewed 70478 times
Album Group context menu
The Contextual Menu for an Album Group in NeoFinder now has commands to create a new Album, or a new Album Group.
It's the little things!
You use Album Groups if you have a lot of Albums, and need to put them into groups.
https://www.cdfinder.de/guide/7/7.1/album_groups.html
Album Group Context menu.jpg (50.53 KiB) Viewed 69130 times
Album Photo Contact Sheet
Did you know that the Contextual Menu for an Album has the option to create a beautiful photo contact sheet from the contents of that Album? Very useful!
Album Photo Contact Sheet.jpg (73.17 KiB) Viewed 67964 times
How to create a Photo Contact Sheet with NeoFinder: https://www.cdfinder.de/guide/17/17.1/p ... sheet.html
How to use Albums in NeoFinder for your photos, videos, or anything else: https://www.cdfinder.de/guide/7/albums.html
Rename with AppleScript!
We keep expanding the AppleScript abilities of NeoFinder for improved automation, and NeoFinder 8.7 allows full read and write access the names of files and folders in Catalogs, and the name of Catalogs and Albums.
AppleScript Album rename.jpg (77.26 KiB) Viewed 66672 times
While that sounds a bit boring, it offers the unique ability to batch rename a lot of items with very specific text replacements.
Check out the sample scripts that NeoFinder installs for you in the AppleScript menu for ideas!
https://www.cdfinder.de/guide/9/9.2/neo ... -menu.html
Write internal XMP into RAW files!
A lot of pro photographers are very clear about NOT wanting to ever write any metadata into the original RAW files.
But then there are those who don't like the separate XMP "sidecar" files this will create.
So NeoFinder now offers the new choice of writing Annotations, Ratings, Captions, and more directly INTO the Nikon NEF, Canon CR2, Hasselblad FFF, and even 3FR files.
If you want this. And only then!
https://www.cdfinder.de/guide/24/neofin ... prefs.html
Topic: Write XMP into known RAW files
More about the powerful XMP metadata editor in NeoFinder:
https://www.cdfinder.de/guide/13/13.1/n ... ridge.html
Write INTO NEF files.jpg (114.22 KiB) Viewed 65715 times
Hasselblad Read and WRITE!
NeoFinder 8.7 will not only read, but also write ratings, annotations, captions, and more to the special ".phos" metadata sidecar files created by the Hasselblad Phocus software, so that you can share your metadata both in NeoFinder and the Hasselblad software
https://www.cdfinder.de/guide/17/17.13/ ... hocus.html
PHOS sidecar.jpg (37.98 KiB) Viewed 64545 times
Set Ratings in Details View
We have massively improved the Details View in NeoFinder 8.7, with customizable fields and all, but you can now also change your Rating for the photo or video right there now!
Details View Ratings Control.jpg (59.38 KiB) Viewed 63490 times
Faster PhaseOne EIP cataloging and progress
Often, it is the little things. Like this:
In NeoFinder 8.7, cataloging very large PhaseOne EIP files is a lot faster now, especially when Updating an existing Catalog.
Also, it now shows the file name and resulting thumbnail in the progress window, so you know what NeoFinder is doing for you...
EIP progress.jpg (28.65 KiB) Viewed 62413 times
Find same TIME!
Did you know that you can search for photos taken at the same time (hour and minute), not just the same date, in NeoFinder? This uses the EXIF Capture Date.
Use the contextual menu for an existing photo for this!
https://www.cdfinder.de/guide/5/5.6/fin ... _menu.html
Find EXIF Capture Date PLUS time!.jpg (266.11 KiB) Viewed 59505 times
Wikipedia Inspector
Did you know that the contextual menu in NeoFinder has the option to open the integrated Wikipedia Inspector for you when you select an item with a GPS GeoTag?
That will show you interesting Wikipedia entries located near the GPS position of your photo or video.
https://www.cdfinder.de/guide/20/20.3/n ... pedia.html
Wikipedia Inspector context menu command.jpg (236.85 KiB) Viewed 58626 times
Users browsing this forum: No registered users and 12 guests
