Empty EXIF Capture Date?
Did you know that the Find Editor has a new parameter in the EXIF section to find empty EXIF Capture Date values?
You can use that to find your images that still need to get an EXIF date.
You can add an EXIF capture date by using the EXIF Date Editor in NeoFinder, or by using the existing date from one file and copying that to other files, using QuickEdit.
https://www.cdfinder.de/guide/17/17.4/e ... ditor.html
https://www.cdfinder.de/guide/17/17.10/quickedit.html
empty EXIF Capture Date.jpg (66.66 KiB) Viewed 3681 times
