NeoFinder iOS 2.5 released!
News about NeoFinder for iOS
Get it here while it is still hot! ;-)
https://apps.apple.com/us/app/neofinder/id862508003
New features in NeoFinder iOS 2.5:
- When a Found folder is selected, NeoFinder iOS displays the content of that folder
- Context menu for a folder to view the Inspector for the folder
- Context menu for a Catalog to view the Inspector for that Catalog
- Context menu for the thumbnail in the Inspector to copy the image to the clipboard
- NeoFinder iOS remembers what was displayed when the app is quit, and restores that state the next time it is launched
- Inspector has left and right arrows for faster navigation to the next or previous item in the Catalog or the list of Found items
- Fullscreen Light Table for items in the Inspector, by tapping on the thumbnail. You can scale the image, and navigate to the next or previous item to show off your photos
- Inspector shows audio BPM (beats per minute) value, if contained in the Catalog
- Inspector shows the XMP fields "Alt Text" and "Extended Description", if contained in the Catalog
- Inspector shows the separate Capture FPS data for video files, if contained in the Catalog
- Inspector shows the EXIF text fields Maker, Image Description, Software Name, Artist, Copyright, User Comment and the unique Image ID, if contained in the Catalog
- New icon for folders
- Many smaller fixes and improvements
Thank you very much for using NeoFinder iOS and for taking your time to read these release notes, we very much appreciate that.
NeoFinder iOS 2.5 content.jpg (116.53 KiB) Viewed 135222 times
Copy the thumbnail!
NeoFinder iOS can now copy the thumbnail from the Inspector, so you can use the image in other iOS apps.
Just use the context menu (long tap) on the image in the Inspector.
inspector copy.jpg (84.18 KiB) Viewed 134952 times
Light Table!
NeoFinder for iOS now has a fullscreen, zoomable Light Table to show you the thumbnails, including the Navigation to the next or previous item.
Tap into the thumbnail of any item in the Inspector to activate it.
The Light Table will open fullscreen, and you can pan and zoom into your thumbnail.
At the bottom, you will find the name of the currently shown image, and navigation buttons to the previous or next item in the catalog, or found items.
The Light Table will ignore all items with no thumbnail.
Leave the Light Table with a short tap into the thumbnail and return to that item shown in the inspector.
More can be found in the NeoFinder Users Guide:
https://www.cdfinder.de/guide/12/12.6/light_table.html
Light Table (medium).jpg (56.95 KiB) Viewed 134558 times
Catalog Inspector added!
#NeoFinder #iOS now has a context menu to open an Inspector panel for catalogs, so you can see how many files are in the catalog, and a lot more.
A long tap on a catalog in the catalog list will show the context menu:
Catalog Inspector context menu.jpg (33.34 KiB) Viewed 134242 times
If you select Inspector, the information will be shown:
catalog inspector.JPG (143.52 KiB) Viewed 134242 times
Inspector Navigation
We have updated the Inspector for an easier navigation.
There are two large, and clearly visible buttons near the top of the Inspector that allow you to get to the previous or next item.
For that, we have removed the small up and down duttons in the top bar, which were harder to use. We also removed the swiping method, which was also tricky and had problems with how iOS handled these transitions.
Inspector Nav Arrows (small).jpeg (97.28 KiB) Viewed 134046 times
Strampalato
Re: NeoFinder iOS 2.5 released!
Post by Strampalato »
Can the catalog file be browsed remotely (on iCloud or other) or must it necessarily be downloaded to the device?
Thank you
To use a Catalog in NeoFinder iOS, you must have a downloaded copy of it on the device, unfortunately.
