NeoFinder library lists all media in triplicate
Chuck
Post by Chuck »
All my cataloged hard disks and DVDs are listed in triplicate in the library list pane. How do I fix this?
Re: NeoFinder library lists all media in triplicate
What verison of NeoFinder are you using?
What version of macOS?
You mean your have multiple NeoFinder catalogs of the same disks showing up in the LIBRARY section of NeoFinder?
Does "Reload database folder..." found in the Special menu help?
Last bumped by Anonymous on Fri Aug 26, 2022 9:09 pm.
