smart folder from
jeffedit
smart folder from
Post by jeffedit »
How do I search or create smart folders from fields not listed in the drop down menu, for instance how to create a smart folder using "location" or "Media". I want to create a smart folder that looks for LTO in the Location or Media fields but can not select those. If I select Any Text and input LTO, then it pulls up any name with lto in it which is not useful. Thanks
Re: smart folder from
As Smart Folders are just saves Find Editor queries, you can only use those fields that are available in the Find Editor.
jeffedit
Post by jeffedit »
Hmm, I guess I don't fully understand the purpose of all the other fields if you can't specifically search and / or sort using them. Any example of how best to use them other than looking at individual assets to see if they have any of these fields entered?
I am not sure what "other fields" you are referring to?
The NeoFinder Users guide explains how the Find Editor works:
Last bumped by Anonymous on Fri Feb 24, 2023 5:08 am.
