We have released NeoFinder 8.3!
We are very happy to announce the immediate availability of NeoFinder 8.3!
AppleScript Galore – Web Gallery Templates – EXIF Editor – QuickEdit for metadata – Bug fixes
New features
AppleScript can be used to access all Catalogs, items in Catalogs, items in Albums
AppleScript can access all attributes, EXIF, IPTC, ID, and others, of Found Items and Catalog Elements
AppleScript can modify many attributes, EXIF, IPTC, ID, and others, of Found Items and Catalog Elements
QuickEdit panel to rapidly copy and paste metadata with a single mouse click in Icon View
EXIF Editor to modify Maker, Model, Author, lens name, and other textual EXIF values
Beautiful Web Gallery Template "Blue Cards" with animations, lightbox, modern CSS code, integrated custom font, and more
Beautiful Web Gallery Template "Green Fluid" with animations, lightbox, modern CSS code, integrated custom font, and more
Catalog thumbnails and metadata of Canon CRM video RAW files
Catalog audio ID3 BPM (beats per minute) information from AIFF, MP3, AAC, WAVE and FLAC, and display it in the Inspector
Added Find Editor options: EXIF User comment contains, EXIF Software contains and EXIF ID contains
Lossless rotation for .MOV and .MP4 video files
Bundles the macOS AutoTags engine in the NeoFinder application, so it can be used without additional downloads
Expert Settings have a list of text file suffixes that NeoFinder will read when Cataloging
Remember selected items in Albums or Catalogs for the next launch
Find AutoTags has the option to select the desired probability
Find AutoTags stored detected tags in the catalog for faster searches
Cataloging progress displays ID3 cover art
RAW images cataloged with libRAW read the unique EXIF image ID
Final Cut Pro project cataloging includes the project version attribute
Export files in text-with-tab contain the full POSIX format path of items from mounted volumes
Separate Catalog or Album windows remember position and size of the window on screen
Drag items from Catalogs into separate Album windows (if content is manually sorted) to any suitable position
Main menu and context menu commands to Copy and Paste the EXIF Capture Date
Main menu commands to remove items from Albums, Found Items, or Catalog and volumes
Lossless rotation for Fuji .RAF files
Paste GPS coordinates copied from Bing Maps
Web Gallery settings window has an option to automatically open the freshly generated HTML export in the default web browser
Assign XMP Presets to all exported Web Gallery thumbnails, to add your copyright information or such
Web Gallery Templates can use item details in the index page
Updated to use the latest version of EXIFTool
Copy and Paste XMP metadata copies custom annotations
Fixes a problem reading size values from DiskCatalogMaker export files in strange formats
Fixes a problem in which writing XMP fields to certain JPG files would change the creator software value as well
Fixes a problem reading the EXIF user comment and EXIF copyright from certain file formats
Fixes a bug exporting multiple catalogs into a XML file
Fixes a bug that showed the wrong commands in the EXIF Capture Date label menu
Removes the closed NeoFinder Twitter page from the Help menu, and adds the new NeoFinder Mastodon social media page
Improves error messages and handling of incomplete or invalid Web Gallery Templates
Fixes a problem getting correct thumbnails for rotated compressed .RAF RAW images
Fixes a problem selecting a previously selected Album in an Album Group during the next launch
Fixes a bug deleting Catalog Folders from LIBRARY that still contained Catalogs
Fixes a bug where writing a new DatabaseSettings.xml in the Expert Settings could fail
Fixes a bug in macOS 12 and macOS 13 where the Photo Export would not remember the entered pixel size properly for larger values
Improves behaviour reading malformed XMP metadata during Cataloging
Works around a new bug in macOS 13.1 that changed the name of the Preferences menu command
Fixes lots of problems introduced by Apple in macOS 13
Fixes many minor issues
NeoFinder 8.3 requires Mac OS X 10.12 or newer, Intel or Apple ARM M1 or M2
NeoFinder 8.3 is another free update for all customers with a NeoFinder 8.x license.
NeoFinder 8.x is a paid upgrade for NeoFinder 6.x, NeoFinder 7.x, and CDFinder customers.
NeoFinder 8.3 – QuickEdit
One of the exciting new features in #NeoFinder 8.3 is QuickEdit. You can rapidly copy and paste metadata of all sorts between files, with just one mouse click.
The NeoFinder Users Guide shows how that works:
https://www.cdfinder.de/guide/17/17.10/quickedit.html
#Apple #macOS #RAW #Catalog #Olympus #Canon #Nikon #Fuji #DigitalAssetManager #Photography #Photographer #PhotoLibrary #PhotographySoftware #PhotographyWorkflow #Photosoftware #IndieDev #DAM #MediaPro #iView #Software #Archive
QuickEdit View Settings Option.jpg (103.12 KiB) Viewed 127229 times
EXIF Editor in NeoFinder 8.3
Edit the text based EXIF fields of your photos and videos directly inside of NeoFinder.
The NeoFinder Users Guide has more and explains how that works.
https://www.cdfinder.de/guide/13/13.9/e ... inder.html
exif editor.jpg (129.07 KiB) Viewed 127074 times
Which do you like better? Blue Cards or Green Fluid?
NeoFinder 8.3 adds two beautiful new Web Gallery Templates, animated, adaptive, customizable, and all.
Which one do you like better?
Green Fluid:
green.fluid Medium.jpeg (84.41 KiB) Viewed 126915 times
Or Blue Cards?
blue.cards Medium.jpeg (94.53 KiB) Viewed 126915 times
AppleScript - The Selection
We have started to expand the #NeoFinder Users Guide with the first AppleScript examples. More will come in the next days.
Let us start with the list of currently selected files in #NeoFinder8:
https://www.cdfinder.de/guide/9/9.6/sel ... cript.html
script-editor- selection.jpg (52.16 KiB) Viewed 126408 times
What is a BPM? ;-)
#NeoFinder8 catalogs and shows you the "beats per minute" BPM value embedded in ID3 tags of songs!
BPM Medium.jpeg (31.32 KiB) Viewed 126068 times
#NeoFinder8 #macOS #Catalog #mp3 #AAC #AIFF #FLAC #DigitalAssetManager #MusicLibrary #AudioProducer #MusicStudio #Apple #IndieDev #DAM #DiskLibrary #DiskTracker #MediaPro #iView #Software #PostProduction #Archives
Copy metadata from NeoFinder to Microsoft Excel
You want to copy data from the selected items in #NeoFinder8 to a #spreadsheet in Microsoft #Excel or Apples "Numbers.app"?
With the new #AppleScript integration, you can create you own custom report and copy it to the clipboard.
A new example in the NeoFinder Users Guide shows you how this can be done and customized to your needs:
copy text-with-tab to clipboard.jpg (30.27 KiB) Viewed 125873 times
GeoTags from Microsoft Bing Maps
Sometimes, it's the small things.
#NeoFinder8 can now use #GPS coordinates copied from #Microsoft #Bing #Maps
These have a different format than #Google Maps.
Paste them in NeoFinder to set the GPS GeoTag to that coordinate.
https://www.cdfinder.de/guide/20/20.2/add_geotags.html
copy GPS from Bing Maps Medium.jpg (89.04 KiB) Viewed 125466 times
AppleScript: Copy Date
What if you wish to copy the XMP Creation Date value to the EXIF Capture Date field?
#AppleScript can do that for you with #NeoFinder8!
The extensive NeoFinder Users Guide has a brand new AppleScript sample that shows you how to move metadata from one field to another.
In this case, the XMP creation date to the EXIF capture date field.
Check it out!
copy xmp date to exif date.jpg (53.6 KiB) Viewed 125463 times
Delete properly!
#NeoFinder8 offers new dedicated delete commands in the main menu to: Remove items from an Album, the Found Items, or from the #Catalog and the physical volume.
That makes it easier to decide what exactly you want to do, and not take any chances.
delete item main menu.jpg (56.09 KiB) Viewed 125149 times
Canon CRM it is!
So many people had asked for it, and #NeoFinder8 can now catalog thumbnails and metadata of Canon CRM video files.
These high quality RAW video recordings are used by many people now, and we are happy that NeoFinder is there for you.
CANON CRM Metadata Medium.jpg (47.69 KiB) Viewed 124890 times
AutoTags Engine bundled!
NeoFinder 8.3 now has the standard "macOS AutoTags Engine" bundled!
No need to manually download it for AI based tagging with #NeoFinder
That is basically the same engine that "Apple Photos.app" uses for its search.
https://www.cdfinder.de/guide/30/auto_keywords.html
AutoTags macOS Engine bundled.jpg (45.85 KiB) Viewed 124612 times
Rotate Videos!
Rotate Videos!
You can now rotate video files in MOV and MP4 format in 90° increments in NeoFinder!
https://www.cdfinder.de/guide/22/22.9/v ... erter.html
rotate videos.jpg (188.32 KiB) Viewed 123915 times
New Find Editor options for EXIF data
Three new search parameters in the #NeoFinder8 Find Editor allow you to specifically search for EXIF software, EXIF comment, and the EXIF "unique photo ID"
Find Editor new EXIF parameters.jpg (64.4 KiB) Viewed 123604 times
Re: Copy and Paste Annotations!
#NeoFinder8 now copies all your custom annotations along with the other XMP metadata fields, if you use the "Copy XMP Metadata" and "Paste XMP Metadata" commands in the contextual menu or the main menu.
https://www.cdfinder.de/guide/13/13.5/n ... ields.html
copy and paste XMP Metadata.jpg (171.54 KiB) Viewed 123129 times
Remember!
It's the little things!
#NeoFinder8 now remembers what items in Albums you had selected when you quit the program.
The next time you launch #NeoFinder, that selected Album will be shown, and the selected items in it selected for you again.
And of course, that also works for selected Catalogs, and the items you hade selected in these as well.
remember album selection.jpeg (78.21 KiB) Viewed 122951 times
