The folder contains files from other applications (-1)
What can cause this error?
An Error occurred while renaming
Re: An Error occurred while renaming
What version of NeoFinder are you using?
What version of macOS?
How exactly did you try to rename the files, using the Inspector, the Multi Renamer, or the name field in the Icon View?
James Ballard
NeoFinder 8.1.2
OS12. Final version at the time of original post.
Tried to rename from Inspector pane.
Behavior is the same on the new Ventura OS.
Does that still happen in NeoFinder 8.2?
James Ballard
Seems fixed. Tested in several separate instances. All is good.
Last bumped by Anonymous on Wed Feb 15, 2023 8:54 pm.
