Q: Is there a way to copy the EXIf caption date to the XMP Creation Date for many photos at once?
A: Yes, there is.
Use the "Move Metadata" tool in NeoFinder: https://www.cdfinder.de/guide/13/13.8/t ... adata.html
Select "EXIF Capture Date" in the From menu, and "XMP Date" from the To menu, then just hit the Transfer button and let NeoFinder do the work.
And while you are at it, make sure to check out the two menus carefully and see what other options they can handle for you in the future.
Copy EXIF Capture Date to XMP Creation Date
