Affinity Photo Thumbnails?
s2art
Post by s2art »
Hi I'm running Mac OS 15.3.2 and Neofinder 8.8 as well as Affinity Photo 2.6.0
This year Neofinder is not displaying Affinity Photo thumbnails correctly? Yet in 2024 when there was a fix sent out they were working.
I have attached 3 screen grabs
my 2025 affinity photo files in the finder
Screenshot 2025-03-30 at 08.52.09.jpg (119.88 KiB) Viewed 19657 times
My 2024 folder of affinity photo files in neofinder
Screenshot 2025-03-30 at 08.47.39.jpg (139.76 KiB) Viewed 19657 times
my 2025 folder of affinity photo files in neofiner
Screenshot 2025-03-30 at 08.46.18.jpg (153.45 KiB) Viewed 19657 times
Re: Affinity Photo Thumbnails?
When did you last Update that Catalog?
Does the QuickLook window in the Finder show the thumbnail?
What cataloging settings do you use forthat Catalog and are there any file types you are excluding in the Expert Settings?
s2art
Post by s2art »
I update the 2025 catalogue every week sometimes 2 or 3 times a week. The 20024 one, I updated in January this year.
Yes the Quicklook window shows the thumbnail
I now have the setting for each catalogue identical, I changed the 2025 one today. This change did not fix the issue. So no I am not excluding any file types across catalogues.
See screen grabs below.
This is the settings for the 2024 catalogue which does show all the affinity photo thumbnails
Screenshot 2025-04-04 at 07.36.03.jpg (52.25 KiB) Viewed 19629 times
this is the old settings of the 2025 catalogue, neither show Affinity Photo Thumbnails
Screenshot 2025-04-04 at 07.36.19.jpg (50.56 KiB) Viewed 19629 times
this is the new settings for the 2025 catalogue, changed today, which still don't show the affinity photo thumbnails
Screenshot 2025-04-04 at 07.53.16.jpg (51.11 KiB) Viewed 19629 times
we cannot reproduce that problem here.
Do you have logging enabled in the NeoFinder Console?
What does it show when you Update a Catalog that contains Affinity Photo files?
Did you upgrade to Affinity Photo 2.6.2 already?
Best regards,
s2art
Post by s2art »
Hi thanks for the prompt responses.
I am now running Affinity Photo 2.6.2
After saving an image using 2.6.2 the problem still presents itself.
I have enabled logging and nothing shows up there either.
does this still hapen with NeoFinder 8.9?
Did you activate Logging in the NeoFinder Consoles, and does that show information regarding the .afPhoto files when you Update the Catalog with these files?
https://www.cdfinder.de/guide/14/14.4/s ... nsole.html
Are these files maybe excluded in the DatabaseSettings?
https://www.cdfinder.de/guide/3/3.10/ex ... oging.html
Best reagrds,
s2art
Post by s2art »
Apologies over my tardy response.
I have activated the logging and can see no obvious errors that relate to the specific folder, although there are some errors, not related to the specific folder, 2025 WIP.
this is the advanced setting, I see nothing here that prevents neofinder from reading the thumbnails, unless I missed something?
Screenshot 2025-09-22 at 11.15.01.jpg (118.58 KiB) Viewed 18069 times
I have tried creating a new sub folder inside 2025, this did not help either.
Ultimately I moved the files back to the 2024 folder and it now the affinity photo thumbnails work.
