I may be missing something but I have a private licence which allows 'Open with' in the context menu when right-clicking an image.
I've noticed that it appears in 8.4.1 on Intel High Sierra but is absent with 8.7.1 on Sequoia (Silicon) and 8.8 on Monterey (Silicon).
I use the 'Open with' to start a photo editor so has something changed? - I can't find any Setting that toggles this feature at all.
Context menu Open with not available from 8.7
Re: Context menu Open with not available from 8.7
the "Open with" context menu command is of course present in Neofinder 8.8 as well.
You will only see it if the file you actually plan on opening is available.
If the disk containing the file is offline, or the name or location of the file has been changed without updating the NeoFinder Catalog, the command will not be added to the context menu.
blatto
Ah yes of course - that is the answer. Thank you for the reply - the folder had of course moved and Neofinder was smart enough to see it unlike moi.
Cheers.
Cheers.
