NeoFinder 8.7.1 for macOS 15 "Sequoia"
We are very happy to report that we have just released NeoFinder 8.7.1, certified for macOS 15 "Sequoia"!
However, due to the large number of problems and bugs in macOS 15, we very highly recommend staying away from macOS 15 as long as possible, especially if you use your Mac for work.
Current known bugs in macOS 15.0:
- The Firewall causes network connections to drop randomly
- iCloud Drive is often non-reposnive and slow
- The SMB client in macOS, needed to connect to NAS for larger file servers, is very slow, causing reading and writing on data from such servers to be very slow
- The Calendar.app can damage your calendars after syncing them to an iOS device
- QuickLook in the Finder is often very slow, and crashes a lot for SVG images (/System/Library/ExtensionKit/Extensions/ImageThumbnailExtension.appex/Contents/MacOS/ImageThumbnailExtension in particular crashes a lot)
We really hope that Apple will quickly start fixing these new bugs, and maybe some of the giant amount of older bugs, too.
The good news is that NeoFinder 8.7.1 also works wonderfully in all previous macOS versions including macOS 10.14 "Mojave", and we did fix all bugs we have seen in our own code so far!
NeoFinder 8.7.1 also has some new features, and we will of course report about them here in the next days.
Download NeoFinder 8.7.1 from here: https://www.cdfinder.de/download.html
NeoFinder News: https://www.cdfinder.de/news.html
Catalog "compressed" NEF photos from Nikon Z8 and Z9
NeoFinder 8.7.1 is now able to catalog the thumbnails and metadata of compressed NEF files created by the Nikon Z 8 and Z 9 cameras!
This is independent of the macOS version, as Apple is unable to read these special RAW files even in macOS 15.0 "Sequoia".
The beautiful sample photos for this screenshot were created by Richard Butler:
https://www.dpreview.com/sample-galleri ... 4934387641
Nikon Z 8 and Z 9 thumbs.jpg (199.82 KiB) Viewed 62654 times
AutoUpdater Logging
The AutoUpdater in NeoFinder 8.7.1 now writes the duration time, as well as the number of files and folders to the log file after updating of a Catalog has completed.
That is very helpful for monitoring what is happening to your cataloged volumes over time.
The NeoFinder Users Guide has more about what the AutoUpdater can do for you: https://www.cdfinder.de/guide/3/3.9/auto-updater.html
Auto-Updater Logging.jpg (60.24 KiB) Viewed 60249 times
AppleScript for "text content"
NeoFinder 8.7.1 adds AppleScript access to the cataloged text content of files. You can find this new property in the Catalog Item in the AppleScript Dictionary of NeoFinder.
Find out more about how you can use AppleScript to automate your NeoFinder workflows:
https://www.cdfinder.de/guide/9/neofind ... cript.html
AppleScript text content.jpg (174.46 KiB) Viewed 59217 times
Where to look?
Reading photo metadata is always an interesting and fascinating topic, for NeoFinder 8.7.1, we fixed a problem where the GPS values in some iOS 17.x (both JPG and HEIC file formats!) versions had a slightly different format and value range that could cause NeoFinder to display the wrong view direction for those photos.
As this fix will only come into play when a photo file is cataloged by NeoFinder, this is a good time to remember that you can also always visually correct the view direction: https://www.cdfinder.de/guide/20/20.6/g ... ction.html
view direction editor.jpg (99.19 KiB) Viewed 58252 times
EXIF Copyright info
Often, it is really the small things that are also important.
NeoFinder 8.7.1 can now catalog the EXIF Copyright information of some RAW foto formats that were previously not covered, like the Fuji RAF files.
Fuji RAW EXIF Copyright.jpg (159.35 KiB) Viewed 56787 times
Source of the sample image: (Dan Bracaglia)
https://www.dpreview.com/sample-galleri ... 4294171440
Work around iCloud Drive problems in macOS 14 and macOS 15
As iCloud Drive is sometimes very unstable in macOS 14 and macOS 15, it can take a very long drive to Catalog your complete startup disk "Macintosh HD" with NeoFinder.
Apart from the fact that you can also just catalog the interesting data folders separately, and thus much faster, we have now filtered out the "Users/*/Library/Mobile Documents/" folder when you catalog the entire startup volume (and only then!).
This is the folder that Apple uses to store your local copies of your iCloud Drive files, and this is the location that can cause NeoFinder to "hang" if there are problems with iCloud Drive.
You can still catalog your iCloud Drive directly, by selecting it in the drive in the Dialog that shows up when you ask NeoFinder to Catalog just a folder.
iCloud Drive problems.jpg (57.34 KiB) Viewed 55608 times
Better support for ID3 in MP3 files!
Reading ID3 tags from mp3 audio files is surprisingly complex, caused by the lack of a clear and consistent definition of tag attributes and languages, and also by the lack of a structured file format for mp3 files.
So we pretty much receive interesting variants and problem files all the time, and improve our custom parser, so you can still reliably get the album name, track, name, cover art, and much more from these songs.
mp3 Tags.jpg (167.76 KiB) Viewed 54811 times
