I'd like to be able to define Ignore options for specific types of files on an "ad hoc" basis, instead of having to globally define them in the Expert Settings panel.
For example, I usually want to index .txt files, but there are a few selected volumes that I want to index that contains a lot of .txt files that I don't need to have indexed.
It would be great if there was a field in the "Ignore" tab of the NeoFinder Cataloging Settings window that allowed you to enter an arbitrary file extension (and even better if it had regex support!) just for that specific indexing session. I could even see a use for more expanded Ignore criteria, such as file-size thresholds, Modification dates, etc.
"Ad hoc" Ignore options?
Re: "Ad hoc" Ignore options?
That is a pretty cool idea, we will discuss this here in the next developers meeting!
Thanks a lot!
Thanks a lot!
