Tip of the day:
If you drag a file from NeoFinder into the Finder, and you hold down the Alt and Command keys when you drop the file, macOS will create an Alias of that file right where you dropped it, instead of copying the file there.
https://www.cdfinder.de/guide/8/8.1/neo ... _drop.html
Create an Alias instead of copying a file!
