abeMeda 7.8 adds a new custom selection
Helpful information about our sister product abeMeda for Windows
abemeda
Post by abemeda »
The new abeMeda 7.8 adds a new custom selection to the display filter:
This allows you to combine multiple item characteristics when filtering your files. All the item kinds and attributes already offered in the display filter can now be selected and applied concurrently, to even better define the files you are looking for. As before, it can also be applied to album contents and found item results.
Custom Selection.png (49.18 KiB) Viewed 67854 times
For the first time, there is now also a section in the documentation about the display filter, including the new custom selection.
displayFilter sm.jpg (116.19 KiB) Viewed 67854 times
