NeoFinder 8.6 out NOW!
We are proud and happy to present you the new NeoFinder 8.6 today!
QuickFind – Display Filter – Image based watermarks – More RAW formats – GoPro – "Concertina" Web Gallery – Catalog Excel files – Bug fixes
We will post details of the new features here in the next weeks, as usual.
Download NeoFinder 8.6 today: https://www.cdfinder.de/download.html
A list with all new features and release notes can be found here: https://www.cdfinder.de/versions.html
More QuickFind!
Let's start with an overview of the new features in NeoFinder 8.6.
The immensely popular QuickFind global search tool has received a massive upgrade.
As requested by many users, you can now specify which types of files you search, and you can also limit the search to just the selected catalogs.
We have already updated the NeoFinder Users Guide with all the new features of QuickEdit for you:
https://www.cdfinder.de/guide/5/5.1/quickfind.html
Of course, the even more powerful Find Editor is also around, and has so many additional abilities: https://www.cdfinder.de/guide/5/5.2/findeditor.html
Another beautiful web gallery: Concertina!
NeoFinder 8.6 adds a new web gallery template, "Concertina", a beautiful way to present your photos on a website.
Check out a live sample here: https://www.cdfinder.de/gallery/Concertina/
The NeoFinder Users Guide has been updated, where you can also download the template if you wish to make modifications!
Concertina Web Template.jpg (113.29 KiB) Viewed 54998 times
To show, or not to show? Display Filter reloaded
The Display Filter in NeoFinder 8.6 has been massively expanded, and yes, you can now hide folders!
A new settings popup window gives you fine tuned control over what you want to see, and you can even use multiple options at the same time, allowing to see just, for example, all landscape photos with a GPS GeoTag, keywords, but no Person data yet.
You can even have NeoFinder only show currently available file on online volumes.
Excel!
NeoFinder can now read textual contents from Apple Pages, Apple Numbers, Apple Keynote, Microsoft Excel, and Microsoft Powerpoint files. That allows you to search for text content in these file types with Neofinder as well.
We have updated the NeoFinder Users Guide for this:
GoPro!
Another often requested ability is reading .GPR files written by the popular GoPro Action Cameras,
The custom GoPro file format has no integrated thumbnails, so NeoFinder needed to be able to actually read and understand the file format. With some help of a code library from GoPro, we were able to accomplish that for you.
Not only will you get a thumbnail and all integrated metadata, including GPS GeoTags, and more, but NeoFinder can also show you the GPS files in its built-in Light Table, and export these photo files into other formats, like JPG or HEIC.
gopro cataloging.jpg (117.22 KiB) Viewed 51241 times
Apple ProRAW
Yes, NeoFinder can catalog thumbnails and metadata of Apple ProRAW photo files!
And you can add ratings, keywords, descriptions and all, too.
And convert these files to other formats.
And check every pixel in the Light Table.
And build beautiful web galleries with them.
And so on.
https://www.cdfinder.de/guide/17/neofi ... hotos.html
Sample Images in the screenshot from: https://www.dpreview.com/sample-galleri ... 4187692333
Watermark with an image!
You could add a visual textual watermark to your converted and exported images and photos in #NeoFinder before, but now you can also add a watermark image as well!
We have updated the NeoFinder Users Guide to contain the latest information about that.
https://www.cdfinder.de/guide/17/17.9/w ... esets.html
Watermark image preset Large.jpg (134.68 KiB) Viewed 49147 times
Olympus ORI files
NeoFinder 8.6 is now able to catalog RAW images in the new Olympus ".ORI" RAW format, and of course you get thumbnails, and metadata for your photo library!
Read more about the many photo formats that NeoFinder can catalog and convert: https://www.cdfinder.de/guide/17/neofin ... hotos.html
Source of sample files: https://www.dpreview.com/sample-galleri ... 7830022316
Olympus ORI thumbs.jpg (157.93 KiB) Viewed 48165 times
More Photo Contact Sheet!
The Photo Contact Sheet in NeoFinder 8.6 has been enhanced with more visual options and colors, see for yourself:
More colors, fonts selection, font size, and also the text adjustment for the Footer.
Photo contact Sheet more color.jpg (138.82 KiB) Viewed 47114 times
Camera Name in Icon View?
The versatile Icon View in NeoFinder 8.6 can display three additional fields:
EXIF Lens Name, Camera Name, and Camera Maker.
Of course, sorting is also possible by these three values now!
Icon View - three new fields.jpg (143 KiB) Viewed 46573 times
Play Sondy MXF videos directly inside of NeoFinder!
Did you know tat the integrated video player in the Gallery View of NeoFinder 8.6 can play Sony MXF video files, if Final Cut Pro X or other Apple software with the Apple Pro Video Codecs are installed on your Mac.
https://www.cdfinder.de/guide/22/22.4/n ... video.html
Filter offline files!
Among many other things, the Display Filter in NeoFinder 8.6 can filter out all items from offline volumes for you, so you see only those files currently available on your Mac!
That means that files cataloged from volumes that are currently not mounted on your Mac can be filtered out. Or only those shown on offline volumes.
display filter online.jpg (65.37 KiB) Viewed 43818 times
More Media Info!
NeoFinder 8.6 offers you a much wider "Media Info" column in List View, so you can see the media details better!
media info column width med.jpg (52.93 KiB) Viewed 42915 times
Copy files
"Save Copy as..." copies files and folders directly from inside of NeoFinder.
This allows you to quickly copy a very large number of files and folders to a new destination.
We had previously used AppleScript to let the macOS Finder perform the actual copy process, but that turned out to be too buggy and slow for more than about 250 files at once.
So now NeoFinder does the copy fast and efficiently itself. And yes, it will also copy along those XMP sidecar files with the metadata in them for you.
We have updated the NeoFinder Users Guide with this information:
https://www.cdfinder.de/guide/8/8.16/save.as.html
save as Medium.jpeg (98.89 KiB) Viewed 38015 times
How many EXIF dates are there?
By default, the integrated EXIF Date Time Editor in NeoFinder writes only the proper "exif capture date" value.
As the EXIF specification allows for three separate date fields, and some other applications read a different field, you can ask NeoFinder to set all three fields to the same value.
As this is used not too often, it is currently a hidden setting, and documented in the NeoFinder Users Guide:
https://www.cdfinder.de/guide/17/17.4/e ... ditor.html
adjust date time ALL THREE.jpg (104.41 KiB) Viewed 37225 times
Video Contact Sheet for Sony MXF!
If Apples ProRes Video Codecs are installed, the Video Contact Sheet in NeoFinder can be used with Sony MXF video files!
If you don't use either Apples Final Cut Pro X, or Apple Motion, and Apple Compressor, you can download the ProRes Video Codec installer separately directly from Apple here: https://support.apple.com/en-us/106396
Find out more about the Video Contact Sheet in the NeoFinder Users Guide: https://www.cdfinder.de/guide/22/22.1/m ... sheet.html
Other video file formats that NeoFinder uses for the contact sheet are: MOV, MP4, M4V, AVI, MT2, M2TS, M2V, TS, MPG, and MPEG.
video contact sheet for MXF files Large.jpg (121.81 KiB) Viewed 35888 times
Video Converter details!
Sometimes, it really is the little things. Like the built-in Video Converter in NeoFinder. If you run it for just a single file (and sure, it can convert many files at once for you, too!), NeoFinder will display the technical details of the original video file.
video converter for one file - details.jpg (123.69 KiB) Viewed 34623 times
Display Filter - Recents!
Use the Display Filter in NeoFinder to tell exactly what you want to see, and what not.
The new "Recents" option for the name filter makes it easier to quickly use the last recently used values again.
We have updated the NeoFinder Users Guide with more details on how that works:
display filter recents Medium.jpg (74.81 KiB) Viewed 34592 times
Video Color Profile!
NeoFinder is able to catalog the color profile description of MP4 and MOV video files, but doing so requires a possibly lengthy query to the Spotlight plugin for video files, which means that this can be really slow.
As a lot of people don't really need that color profile name, we have deactivated that feature by default to make sure that cataloging runs as fast as possible.
But if you want to see that information, well, here it is:
https://www.cdfinder.de/guide/22/22.2/m ... adata.html
Topic: Video Color Profile?
video color profile.jpg (84.51 KiB) Viewed 34591 times
