Copy files to new location?
Q: 1) I use to NeoFinder to catalog a petabyte of video storage that lives on 3 servers.
2) Using NeoFinder I can search for files with similar names. For Example “TARDIS”. Those files are on various mounts.
3) Can I use NeoFinder to copy all those files to a new location. (An external drive.)
A: Actually, yes, you can, either drag the files from NeoFinder to the desired destination folder, or use the "Save Copy as..." command in the Item menu.
Then sit back and relax. ;-)
