I am working on using neoFinder to index all of my old photos.
My question is what metadata tag should I use to enter the names of individuals in the photos?
I want to be able to use smart folders in neoFinder as well as have the Spotlight search in mac to find all images I have with a name. I have tiff, jpg, heif, and pdf images.
Thanks Roger
Metadata Tags
Re: Metadata Tags
you want to use the Persons metadata field:
NeoFinder also helps you with a Persons list and auto-completion upon entering names to avoid spelling errors.
Last bumped by Anonymous on Sat Aug 27, 2022 1:59 am.
