HI, I just realised, it's better for my Digital Asset Management to have different Databases for different purposes.
It would be great to show them side by side (like in Capture One / Media pro), and have a list of used databases, without go into NeroFinder and select them manually.
Only problem the Albums should be also fixed to it's database…
Database List Switch
Re: Database List Switch
You mean different catalogs of the same data? No problem, just use them with NeoFinder as well.
Media Pro could only handle very few files in its tables, so you had to use many multiple tables, and open and close them manually.
NeoFinder doesn't have that limitation.
Last bumped by Anonymous on Sun Aug 28, 2022 7:47 pm.
