Asset indicator as to album/library/folder location
nbtsf
Post by nbtsf »
Hi,
Just started using NeoFinder after using Media Pro/iView since the early years. Also using Neofinder concurrently with Lightroom and Capture1.
Loving the speed and features of the program so far.
One question at the moment, Is there a way when assets/thumbnails are selected in the main window, that there is a way to indicate in which current Albums/Library/Smart Folder the assets also live? Meaning , when an asset(s) is selected , there could be a check or highlight in the left column/window area next to the appropriate Album/library/Smart Folder?
Or perhaps that info could also be available in the Info area in the right window/column area?
Hoping this is already in the software or perhaps something that can be implemented?
nbtsf
Re: Asset indicator as to album/library/folder location
Post by nbtsf »
Just bumping and hoping for an answer on this question.
Thanks!
You are right, the information about being part of one or multiple Album(s) is currently not easily available. We are looking into that...
