Map search for Places
We have discovered a problem in the place name search of the Map in NeoFinder.
The OpenStreetMap-Server that NeoFinder uses for this feature, has started to return a slightly different data reply format, which NeoFinder did not recognize.
We have added code to NeoFinder today so that this will work again.
If you use this feature of the NeoFinder Map, please contact us for a developer version with that fix.
NeoFinder Map Place Search.jpg (137.95 KiB) Viewed 3742 times
