Catalog 3D-Printer files!
Q: Can NeoFinder catalog STL files?
A: Yes, NeoFinder is indeed able to get you a thumbnail of the 3D printer STL (Standard Tessellation Language) file, if you ask it to do so.
Open the DatabaseSettings and add ".stl" to the "Catalog QuickLook Thumbs for" list. Write the settings, and catalog a folder of STL files.
https://www.cdfinder.de/guide/3/3.10/ex ... oging.html
Settings for STL files.jpg (106.13 KiB) Viewed 7047 times
Please make sure that the option to generate Photos thumbnails is enabled, as NeoFinder treats QuickLook previews as photos.
STL thumbnail.jpg (96.96 KiB) Viewed 7047 times
