small bugs in recent update
Re: small bugs in recent update
There is no separate XMP Keywords field, just the combined "Keywords" field which also shows the Finder Tags in the List View.
Thanks for the notice about the Video bitrate column, that is indeed a bug that will be fixed ASAP.
s2art
Post by s2art »
I am having trouble with my "smart folders". All the special rules I have created have disappeared. There is now blank fields where I had carefully written rules to find based on several criteria. Mostly labels. In the screen grab below, I created a "smart folder" in my previous version of Neofinder that had the following parameters.
All of the following are true
every catalog file
kind is raw
label is "red"
All of these have been wiped by the new update.
When I try to create the rules the "label is... " part does not work. Other parameters work, for example exif data.
However the pre-baked ones that come with the app still work?
Screen Shot 2023-05-16 at 10.57.25a.jpg (122.61 KiB) Viewed 6353 times
Make sure to use the new NeoFinder 8.4.1. it fixes this.
s2art
Post by s2art »
neo-admin wrote: Tue May 16, 2023 9:58 am Make sure to use the new NeoFinder 8.4.1. it fixes this.
WOW!
Thanks for the prompt response and update.
I have updated and m back to my usual workflow now
Thanks again
Our great pleasure!
